i have the GIGABYTE GA-Z77-D3H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
and i was wondering if it has enough spaces to hold all this components. Any help would be useful because im kind of a noob at this.
These are the GIGABYTE Specs:
Number of Memory Slots: 4x240pin
PCI Express 3.0 x16: 1
PCI Express 2.0 x16: 1 @x4
PCI Express x1: 3
PCI Slots: 2
SATA 3Gb/s: 4 x SATA 3Gb/s
1 x mSATA connector (The SATA2 5 connector will become unavailable when the
mSATA connector is installed with a solid state drive.)
SATA 6Gb/s: 2 x SATA 6Gb/s
Onboard USB: 2 x USB 3.0 + 6 x USB 2.0
Other Connectors: 1 x 24-pin ATX main power connector
1 x 4-pin ATX 12V power connector
1 x mSATA connector
1 x CPU fan header
3 x system fan headers
1 x front panel header
1 x front panel audio header
1 x S/PDIF Out header
1 x serial port header
1 x Clear CMOS jumper
1 x Trusted Platform Module (TPM) header
The components i want to connect:
1. EVGA SuperClocked 02G-P4-2662-KR GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI
Support Video Card
2. CORSAIR Builder Series CX600 V2 600W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply
3. CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model
CMZ8GX3M2A1600C9
4. ASUS Black Blu-ray Drive SATA Model BC-12B1ST/BLK/B/AS - OEM
5. Western Digital 1 TB WD Blue SATA III 7200 RPM 32 MB Cache Bulk/OEM Desktop Hard Drive
6. OCZ Vertex 4 VTX4-25SAT3-64G 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD)
7. Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
and btw the case has front ports: Power & reset button with blue LED
2 x USB 3.0
Audio In and Out
and also these fans: 1 x 120mm TriCool rear fan with 3-speed switch control
2 x 120mm TriCool blue LED front fans with 3-speed switch control to cool HDDs
1 x 200mm top fan
Any information would help, im building a gaming computer and i dont want to have some of these parts not fit because of lack of ports in my motherboard.
PCI Express x1: 3
PCI Slots: 2
1 x mSATA connector
1 x CPU fan header
Support Video Card
CMZ8GX3M2A1600C9
2 x USB 3.0
Audio In and Out
1 x 200mm top fan
