does multiple cores effect speed
MR ORANGE
Commendable
Mar 13, 2016
30
Pc 1 has 2 cores, clock speed= 2.75ghz
Pc 2 has 4 cores , clock speed= 2.50ghz
which cpu will be able to procces the fastest
It depends. Can the software use all cores? Some do, some don't
Consider a 2 lane road with a 60mph speed limit, and a 4 lane road with a 50mph speed limit.
Both at max capacity.
The 4 lane will allow more cars per hour. Almost but not quite twice as much.
But if you (the software) can only drive one car at a time (one core), then the 2 lane road with the faster limit wins.
It depends on the software and the architecture of the CPU. AMD CPUs at the same clock speed have been slower than Intel CPUs for a long time (less efficient). If the software can only use one core then the higher clock speed wins. But if the software can efficiently use all cores then the multi-core wins.
The processor generation makes a difference too. For the most part, each generation of processor is a bit faster than the previous, getting moer performance per clock. So, even though the one processor might be clocked higher at 2.75 GHz, if it's a few generations older than the 2.50 GHz one, there's a good chance that it will be slower.
Additionally, these processors might boost to different speeds under load. Just because one processor has a higher base clock, doesn't mean it will boost to a higher speed than the other when presented with a heavy processing task. To provide a more definitive answer, we would need to know exactly what model the two processors are, and what you intend to use them for.
