does multiplug reduce current flow
Mahbub1
435
does multiplug reduce current flow? if i put a multiplug betwen pc plug and ups without putting other appliance in the same plug so does that reduce flow of current? its because my power cable is american style means rectangular.. and ups cable plugs are indian means rounded.. so does putting the multiplug reduces my current? and also the multiplug is a surge protector so putting in the wall connector too reduces current flow?
A ballpark figure might be 0.3V drop so it would have to be a borderline bad power supply to matter. Power grid voltage varies by much more.
actually i have to cz indian style is rounded while american is rectangular so the multiplug is acting sort of a converter from us to indian style,, should i continue using it? and is there anything to be tensed?
If an adapter is reducing current, then it gets hot. GearUp's numbers apply. That 0.3 volt drop due to current restriction is so close to zero that a hand should feel no heat. No electronics problems also for reasons he has provided. No heat; no problem.
