Does my 400W power supply have a 6-pin connector for a GTX 960?
According to the specs it should have a single 6-pin connector. But the PSU itself is low quality and I would not suggest powering a gtx 960 with it. I wouldn't even power a 750 ti with it.
I'd rather have an answer online then to go open the back panel and mess up all my cable management. (I don't have zipties you know!)
I'm actually powering a 750TI without a 6-pin only using PCI-E x16
Oh, thanks for the explaination, I'm not going to recommend iBuyPower systems anymore. My computer is based off a iBuyPower computer, just home-made and custom fans.
