[SOLVED] Does my GeForce 2080 Ti card have to be married to a G-sync capable monitor to avoid problems?
novicebuilder1049
9
I am building a new computer with: AMD 3900x CPU, GeForce 2080 Ti card, 32 gigs of G Skill Trident Z (CL 14) RAM mounted on a X570 Gigabyte Aorus Master m/b and using an Arctic liquid freezer on the CPU. All placed inside a Corsair Obsidian case. Spent most of my budget here. Looking for a good 2k monitor (in the $550) to get started with. Suggestions welcomed !
This is what I, and many others around here, are using with our Nvidia cards. Fully compatible with G-sync. Excellent display. Great gaming monitor. Particularly cheap if you live close enough to a Microcenter to go pick one up or can order from one, or can catch a sale on one of these at another vendor since they go on sale pretty frequently.
https://www.microcenter.com/product...qhd-144hz-dp-hdmi-freesync-led-gaming-monitor
https://www.amazon.com/LG-32GK650F-B-Monitor-FreeSync-Technology/dp/B07FLGR2PN
If you WANT to spend the money on an actual G-sync display, this would be a good option, but personally I'd save the money and go with the...
If you WANT to spend the money on an actual G-sync display, this would be a good option, but personally I'd save the money and go with the G-sync compatible Freesync model.
PCPartPicker Part List
Monitor: LG 32GK650G-B 32.0" 2560x1440 165 Hz Monitor ($449.99 @ Adorama)
Total: $449.99
Generated by PCPartPicker 2020-02-08 22:39 EST-0500
novicebuilder1049
9
Total: $449.99
Darkbreeze,
All the links were very helpful. I went for the higher priced monitor for peace of mind. I appreciate your input !! Can't wait to get this up and running.
Thanks
