AMD Athlon II X4 750K, 3400MHz, 4MB, socket FM2, Black Edition
MSI FM2-A75MA-E35, socket FM2
HDD WD Blue, 1TB, 64MB, 7200rpm, SATA 3
Memorie Kingston 8GB 1600MHz DDR3 Non-ECC CL9 DIMM (Kit of 2) XMP HyperX Blu
Flash SSD Kingston V300 2.5", 60GB, SATA 3
Carcasa Nox Cyclops, Midi Tower, ATX, fara sursa, neagra
Sursa Inter-Tech Energon 650W
This configuration is built on a budget. I realise it is weak from gaming perspective. I work from home and the system must run POSTGRESQL database with emphasis on RAM/SSD/CPU (the GPU has little or no effect they say) in this order. I already have a PCI-E decent GPU(I don t know the model...i am pretty noob). I only ask if the components fit together. I got optical drive also. Sorry for insufficient details.
