does my memory work with my mtherboard?
Jan 30, 2019
hi all,
my mother board is a Gigabyte GA-A320M-S2H version 1.0
but i got really confused by youtubers saying qualifeid ram but what would happens
when i dont have a "qualifeid" ram. the ram i want to use is CMV4GX4M1A2133C15
it would really help if this gets solved becuse im new to pc building.
Yes, I believe that your RAM will work with you motherboard. Most do, when they talk about qualified RAM it is just RAM that has been tested with that motherboard. It doesn't mean that you're RAM won't work. The best way to test if it works is to stick it in and boot it. Nothing will occur to damage your RAM.
Good Luck and Happy Building!
