What do u mean by properly will it still work? Or is it a requirement? I'm on a tight budget for my setupYou will need an external phantom power supply, or soundboard, in order to properly run that mic.
Do u have any reccomendations for budget mics that dont need a phantom power supplyIt is a requirement.
Additionally, I dont know what quality you are expecting out of a 27 dollar condenser mic, its not going to be great.
actually do u have any reccomendations for headphones with good mics under 50$?Not really, they are all going to be about the same quality.
If you want quality audio (which it seems like you do), then you are looking at spending over 150 dollars.
For that low end, just buy an antlion modmic.
