I was thinking about upgrading my GTX 760 to a GTX 970 lately because I'd like to be able to handle all these next gen games at very high or ultra settings, such as the Witcher 3 or Arkham Knight. I'm not very familiar with how certain hardware parts may fit into a case or motherboard, So I read up on it a bit and found that most of them fit using PCI slots or something, and even that a 970 can work with a PCI gen 2.0.
So what I want to know is:
-Will this work with my motherboard & fit in my case
-If so, since it will be my first time changing a big piece of hardware, should I have a professional do it or do you think It's easy enough
Here's my Motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130700
Case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133179
And the GPU I would like:
http://www.amazon.com/MSI-GTX-970-4GD5T-OC/dp/B00NN0GIA0/ref=br_lf_m_11450166011_1_11_ttl?ie=UTF8&s=pc&pf_rd_p=2087853482&pf_rd_s=center-3&pf_rd_t=101&pf_rd_i=11450166011&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=035JDQFZD78AGHB8M776
Just in case, I have an i7 4770 and 16 gb ram
thanks
Case:
thanks
