Does My motherboard Memphis 2-s work for gtx 1060, 1050 or gtx 960, 970?
You saying that Asus dual GeForce gtx 1060 OC graphic card 6gb will work? Because I’m thinking of buying that.
So long as you have a suitable power supply and the card physically will fit your case, then it should be fine. You STILL may need to update the bios on your motherboard IF there is a newer one available than what is currently installed prior to installing the new graphics card for best compatibility, but even brand new motherboards have been known to need that recently AND in the past.
