Does my motherboard work on newer graphics card?
Jamkat388
19
Need help on my upgrade graphics card... Have a Lenova H430 I5 2320 8g ram with AMI Aptio AV 10 motherboard. I need to know if my PNY gtx960 can handle it? I have upgraded power supply to a 550 watt dc 12volt 22 amp. Don't know if it's enough. I think it recognizes it. I get a Lenova logo screen then after 3 seperate beeps about a minute apart and then black screen with a type of card description on the upper left of the monitor. And then a few seconds later a bunch letters and numbers disappear from the description. No boot up. Can anyone help?
pre-builts may have locked bios, that prevents upgrades
reset cmos
go into the bios and set primary display to PEG
set UEFI to legacy mode
reset cmos
got it running?
The UEFI setting is in the BIOS menu
You go into the bios and look for UEFI, CSM, or secureboot
set to "legacy", or "disable", or "compatability"
for resetting the cmos, you need to read the motherboard guide on the steps it specifically needs to do this
or you can open your computer yourself after turning it off and look at the motherboard, it will usually have a jumper that has written on the mobo itself "clear cmos"
if you are not able to go into the bios, you might need to take out the new gpu first to go into the bios
