Does my p8h61m lx2 supports zotac gtx 1060 6gb single fan
Rao_Mubashir
12
So i am currently using p8h61m lx2 not the p8h61m lx2 R2.0 and im going to buy zotac gtx 1060 6gb single fan will this gpu works fine with my P8h61m lx2 my bios are updated and i will also buy a new psu
And one strange problem that i have noticed is that when i install afox g210 1gb 64bit in my mobo my fps get drop in games
I am currently using
Processor: 3470
motherboard: p8h61m lx2
Ram: ddr3 1333mhz 8gb
Afox g210: http://www.afox-corp.com/en/products_details.asp?proid=211&typeid=47&id=0
Thank you....
I wouldn't go over a GTX1050Ti 4GB on that setup. What PSU are you looking at and what do you have at the moment? Your issue with frame drops can be the result of a corrupt GPU driver, if you're on Windows 10, your PSU being faulty or that your system is being taxed with latter generation, more demanding game titles.
You've missed to mentioned the above information.
here is my psu
https://drive.google.com/open?id=1Un879LQWSE48XqEW1wIwCgJbSPTNIXXU
open
