does my PC build work?
benwalker1
5
CPU:
Intel Pentium G3260
Motherboard:
MSI H81M – E34
Memory:
Mushkin Enhanced Stealth 8GB (2x4GB) DDR3 1600 model 996995
Storage:
Seagate – Barracuda 1TB 3.5 7200RPM Internal Hard Drive
Graphics Card:
NVIDIA GT 1050 Ti
Case:
Thermaltake versa H25
Power Supply:
Antec EarthWatts 380 Watt power supply
PC Tailor
Respectable
Jun 29, 2017
1,136
24
2,665
317
No, the motherboard and RAM are NOT compatible with the G4560, the G4560 is new 1151 socket, whereas the motherboard is 1150 (Older generation Intel processors).
To get the G4560, you will need a motherboard and RAM change.
benwalker1
5
Thanks for the feedback I have changed the thread to suit the PC requirements. Thanks :)
Supahos
Champion
Herald
If you're wanting to game that will still fall on it's face. You'd want at least an i3. The g4560 has hyperthreading like an I3, the Pentium you listed does not and it will severely limit your gpu in many titles, and make some flat unplayable
Similar threads
