You also need to take into consideration the rest of your system, as that also uses a fair bit of power. NVIDA recommend a minimum of 600watt, as the graphics card uses 250 watts. Most likely it will be cutting it fine, and you will need to add up the power requirements of the rest of your system. You might be able to do this easily by using another graphics card temporarily in your system, and see how much power you are using then.
