Hi. So I built my first system fot fun a few weeks ago but after trying to overclock my AMD FX 8350 cpu using the software the MSI Mobo came with I ended up frying the mobo and probably everything else since I saw smoke come from mobo and then I got a black screen and even trying to switch everything out still nothing. So I RMA'd almost everything from Newegg and ordered new hardware. So this time I'll be much more carefull. But this time I decided to upgrade a few things so I need to know if I did indeed buy a PSU with enough Wattage for my build.
Please let me know if I have enough wattage but only if you yourself are experienced in PC'S and know exactly what you are talking about!
You can comment on my build too but please if you have nothing intelligentnto say then don't say it all.
Thank you all ahead of time.
SO HERE GOES.
MY SECOND ATTEMPT AT FIRST BUILD.
1. Antec Twelve Hundred V3 Black Steel ATX Full Tower Unbeatable Gaming Case--$119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129100
2. ASUS Crosshair V Formula-Z AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Gaming Motherboard with 3-Way SLI/CrossFireX Support and UEFI BIOS--$229.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131876
3. AMD FX-8350 Vishera 4.0GHz (4.2GHz Turbo) Socket AM3+ 125W Eight-Core Desktop Processor--$209.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284
4. EVGA SuperClocked+ 03G-P4-3663-KR GeForce GTX 660 Ti 3GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card--$339.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130812
5. EVGA 03G-P4-2669-KR GeForce GTX 660 FTW 3GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card--$279.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130844
6. (2Sets of 16GB=32GB) G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL10D-16GBXL--$49.99 & $69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231489
7. Thermaltake WATER2.0 Performer Closed-Loop All In One Liquid CPU Cooler Dual 120mm PWM Fans 120x25mm CLW0215--$84.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106188
8. ADATA XPG SX900 ASX900S3-256GM-C 2.5" 256GB SATA III MLC Internal Solid State Drive (SSD)--$189.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211597
9. Western Digital WD Green WD20EARX 2TB 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive--$109.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136891
10. Western Digital WD Green WD5000AZRX 500GB IntelliPower 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive--$69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236155
11. LITE-ON 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 8X BD-ROM 8MB Cache SATA Blu-ray Burner with 3D Playback iHBS212-08 LightScribe Support--$99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106348
12. Rosewill 2.5-Inch SSD/HDD Mounting Kit for 3.5-Inch Drive Bay w/60mm Fan RDRD-11003--$7.99
http://www.amazon.com/gp/product/B007HJ5R32?ie=UTF8&force-full-site=1&ref_=aw_bottom_links
13. G.Skill Turbulence II Memory Cooling Fan 3500rpm--$19.99
http://www.amazon.com/gp/product/B0041G211U?ie=UTF8&force-full-site=1&ref_=aw_bottom_links
14. Thermaltake iCage A2309 HDD Module with 12cm Blue LED Fan--$23.65
http://www.amazon.com/Thermaltake-iCage-A2309-Module-12cm/dp/B000B898N6/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355593610&sr=1-1&keywords=Thermaltake+HDD+Cage
15. NZXT SENTRY 2 Accessories 5.25-Inch Touch Screen Fan Controller (Black)--$24.99
http://www.amazon.com/SENTRY-Touch-Screen-Fan-Controller/dp/B002L16OMO/ref=pd_sim_pc_23
16. AeroCool Touch 2100 5.25-Inch Touch Screen 5 Fan Speed/Temp Controller--$69.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4904465&SRCCODE=MDOTTD&MobileOptOut=1
17. (2 Extra Fans for Side Panel and Center) Antec TriCool 120mm Blue LED Cooling Fan with 3-Speed Switch--$10.43 x 2 = $20.86
http://www.amazon.com/Antec-TriCool-120mm-Blue-LED/dp/B00066FHEW/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355616335&sr=1-1&keywords=antec+120mm+case+fan
18. Hard Drive: 1TB SATA-III 6Gb/s 7200RPM HDD
Optical Drive: 24X DVD±R/±RW Dual Layer Drive
(I also am going to add this 1TB HDD & 24X DVD Drive that I had from my previous system)
Finally The Power Supply Question. Will This Be Enough Wattage?
19. KINGWIN Lazer Gold Series LZG-1300 1300W SSI EPS 12V v2.92 Yes Yes 80 PLUS GOLD Certified Modular Active PFC Power Supply--$214.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817121091
Anyways, that's my build. I know there is a lot of things included, but I wanted something that I can use for games and multi-tasking, watching movies and downloading and listening to movies, etc. So I hope some of you pc experts can check out my build and tell me if my system has enough wattage with the 1300W.
Thank you.
SO HERE GOES.
Thank you.
