Does my system configure (work well together)?
thepcgamer099
262
Does my system work well together and is it able to run lots of modern high spec games on high settings? Also which out of the two cpu coolers listed below should i get? Here is my system...
Intel i5 3570k
asrock z77 extreme 4
Nvidia geforce gtx 760
(x2) 8GB ballistix tactical lp
Seagate 2 TB HDD hard drive
Samsung 840 120GB SSD Hard drive
Corsair carbine 500R case
OCZ Modstream 500w psu
Thermolab trinity CPU cooler or Cooler master seidon 120m cpu cooler
Also I might be overclocking this system a little as well (only a small bit though not maximum I don't want cpu blowing up)
Thanks
Don't buy 2 8gb sticks of memory, buy a 2x8gb kit so that they'll work together by simply enabling xmp, buying two single sticks MIGHT not work properly.
Rest of the system looks pretty solid, I wouldn't buy an OCZ power supply as they are in bankruptcy and generally junk anyway. I would likely go with a 550~600 watt power supply from Seasonic/xfx/corsair/or rosewill that are 80+ bronze rated.
thanks i am looking at the changes now so would you recommend a rosewill psu rather than corsair (based on performance and slightly on price)
