M MLeoman Prominent Feb 17, 2017 4 0 510 Feb 17, 2017 #1 guys ive been thinking if my graphics card will work on a ddr3 RAM ??
Solution LucaFire Feb 17, 2017 As long as you have a PCIe 16x slot, I would think so. If this is a prebuilt system, I would be more skeptical.
LucaFire Distinguished Jul 2, 2014 1,117 0 20,760 Feb 17, 2017 Solution #2 As long as you have a PCIe 16x slot, I would think so. If this is a prebuilt system, I would be more skeptical. Upvote 0 Downvote Solution
M MLeoman Prominent Feb 17, 2017 4 0 510 Feb 17, 2017 #3 LucaFire : As long as you have a PCIe 16x slot, I would think so. If this is a prebuilt system, I would be more skeptical. ok thanks man ... Upvote 0 Downvote
LucaFire Distinguished Jul 2, 2014 1,117 0 20,760 Feb 17, 2017 #4 No problem. If your question is resolved, just pick a solution and that will close the thread. Upvote 0 Downvote
RCFProd Expert Ambassador Dec 8, 2013 12,605 29 56,990 Feb 17, 2017 #5 Should definitely work. Which power supply do you own? Upvote 0 Downvote
M MLeoman Prominent Feb 17, 2017 4 0 510 Feb 17, 2017 #6 RCFProd : Should definitely work. Which power supply do you own? i got a RISE Model: P4-600w power supply Upvote 0 Downvote
RCFProd Expert Ambassador Dec 8, 2013 12,605 29 56,990 Feb 17, 2017 #7 It's a low quality generic branded power supply. Not ideal either. Upvote 0 Downvote
LucaFire Distinguished Jul 2, 2014 1,117 0 20,760 Feb 17, 2017 #8 No, it's not... :/ Unfortunately! Upvote 0 Downvote
