Question Does Noctua NH-D15 fit Thermaltake Core v31 case?
rubevanlaar
Hi,
I currently have a i7 7700k and a Corsair H100i v2.
I'm considering switching to Noctua NH-D15 to avoid problems related to pump failure/leakage after i saw couple reviews (including Jay2Z's) on the Noctua. My setup is now over 1 year old.
I have a Asus 1080ti strix and i'm almost freaking out after i read several cases about Corsair pumps failing/leaking. I paid hefty money for this setup and don't wanna have my gpu/mobo fail cause of that. The problem here (and i digress) is that i live in Syria, so even when Corsair's warranty covers the product i can't ship the AIO to them if anything wrong happens, nor can i receive refund (which they probably won't). I can however order from Amazon through a 3rd party reseller.
Now, the question is:
Can my Thermaltake Core v31 fit the Noctua aircooler?
I went on the website of both products and found that my case only supports 155mm height aircoolers, BUT before the Corsair AIO i had a Thermaltake Frio Advanced aircooler with 159.2 mm height that fit fine.
Links below for reference.
If anyone has said configuration of aircooler and case could advise on the matter, would appreciate it.
Thanks
https://www.amazon.com/dp/B00L7UZMA...olid=3761EGXH9W2ND&psc=0&ref_=lv_ov_lig_dp_it
https://www.thermaltake.com/products-model_Specification.aspx?id=c_00002469
https://www.thermaltake.com/products-model_Specification.aspx?id=C_00001822
