Does not boot or display to monitor
Oblivionage
35
Hello I built a new system maybe 2 weeks ago just got all my parts
cpu: i5-3570k
gpu: (friend lent me an hd radeon 5830)
monitor: takes in vga i've used it for years
psu: antec 750w psu not sure exact model
case: zalman z11 i think
ram: kingston hyper x 4x2 gigs
mobo: msi z77 g45 motherboard
hdd: i tried 3 different ones 1 i used to have and 2 other my friend gave me. all 160-250gb seagate barracuda 7200rpm drives
anyway so my issue is that when i tried to boot my system externally, there would be no signal to the monitor (using the integrated graphics) and it would fail to boot (i think can't be sure without a display).
I noticed i used the wrong screws at first so it left a little scraping on the mounts. The 6 dots that represent the mounting points all got mixed together by the scraping and my friends said it shouldn't matter. I also very thinly scraped the side trying to put the gpu in but it only shows a very thin silver mark.
My idiotic reasoning was "oh the motherboard clearly is at fault let's replace that!" so i rma'd it i had a 2 year warranty on it)
The reason i didn't test the gpu as well is because i didn't have a dvi to vga adapter and for some reason i was really convinced the motherboard was at fault. So if i luckily receive my motherboard back in one piece or get a replacement from newegg what should i do?
I mean i guess the first thing to do is check to see if the gpu works and send a signal. I'm really afraid it's the cpu's fault that the boot is failing and sending no signal to my monitor.
If the above is the case does microcenter replace parts? I really would hate it if it was a doa brand new cpu..
Okay i'm going to go back and edit this when i get home i just wanted to get this out here while I am free. Thank you very much for the help 😀
Our troubleshooting checklist will help you narrow down what's causing the problem if you're still having problems when you get your replacement motherboard.
my rma has been approved so i'll be waiting on that to check if it actually was the mobo (doubt it). At least that'll be out the way. Seriously though any suggestions will be appreciated or any questions as to what i'm even talking about.
