Question Does not recognize lan port 2 3 4
Dec 12, 2020
Hello! . This is a bit of Networks but hopefully they can help me. I have a Nokia wifi router that sends wifi signal and there is a network cable connected that connects to a pc. Now I want to connect another cable. The first is connected to the LAN 1 port and the second is connected to the LAN 2 port. What happens is that the LAN 2 tells me Unidentified Network. It is not the Computer because it happens to whatever computer you connect it to. I do not know if it will be something from the Router and that. If anyone knows something great. Thank you
Which model Nokia router?
On the computer you are trying to connect did you disable the wireless network adapter and ensure that only the wired network adapter is enabled? What wired network adapter is being used: built-in, USB, PCIe?
What happens if you connect the working computer on LAN 1 to LAN 2?
Did you try connecting Computer 2 to LAN ports 3 & 4?
Did you try another known working Ethernet cable to LAN ports 2, 3, and 4?
Run "ipconfig /all" (without quotes) via the Command Prompt on both the working computer on LAN 1 and the failing computer on LAN 2.
Post the results.
