does onboard Realtek sound rob CPU power ?
mahanddeem
496
Hello,
In gaming, would onboard sound like Realtek would consume some CPU power? and in comparison to dedicated sound card ?
Does the same applies to onboard LAN ?
no, the sound is a separate processor on the motherboard to handle sound. same with the lan. both are separate from the cpu and use no more cpu cycles than an add on card would.
as the chips got cheaper and smaller, they were simply included on the mobo as a value add on. then slowly they just became standard features.
for gaming the onboard sound is plenty good enough. the add on cards are really only needed for audio production and processing type activities. you get 7.1 surround sound out of onboard these days which should be plenty for any normal pc use :)
save your money and use the onboard
A few cpu cycles in todays cpu's means nothing. That is like asking will my lunch bag slow my car down on the drive to work....
CPU processing power is really a non issue. Your question about 892 vs 1150 vs PCI/PCIe is more about SOUND QUALITY.
Since you're buying a new motherboard get a quality board with 1150 audio chip which I believe is the newest. In my experience a good sound card is BETTER but you also need good speakers or headphones to notice the difference.
PCI vs PCIe:
There's no difference except what sound cards are available and what free slots you have.
Summary:
I suggest building the PC first with an 1150 socket board, get reasonably good speakers then come back to the decision of whether a sound card would be of benefit.
