5 50bmg Distinguished Nov 16, 2007 906 2 18,985 Jun 22, 2020 #1 Does PRIME X570-PRO flash bios without a cpu? edit: I guess the right question is will it support Ryzen 3600? Last edited: Jun 22, 2020
DMAN999 Dignified Ambassador Apr 17, 2019 3,279 996 16,940 Jun 22, 2020 #2 No, it does not have a BIOS Flashback feature. So to update the BIOS you will need a compatible CPU installed. Upvote 0 Downvote
5 50bmg Distinguished Nov 16, 2007 906 2 18,985 Jun 22, 2020 #3 I guess the right question is will it support Ryzen 3600? Upvote 0 Downvote
kurdtnz Honorable Feb 24, 2020 2,223 370 12,640 Jun 22, 2020 Solution #4 Being an x570 board,it should support 3rd gen straight from the box. Upvote 0 Downvote Solution
DMAN999 Dignified Ambassador Apr 17, 2019 3,279 996 16,940 Jun 22, 2020 #5 Yes it does, as long as it has BIOS 0704 or newer: https://www.asus.com/Motherboards/PRIME-X570-PRO/HelpDesk_CPU/ Upvote 0 Downvote
