I am aware that the fpi of a rad affects the static pressure required of a fan quite a bit due to the restricted airflow. However, does the thickness of a rad make a difference? Surely more surface area = more force needed to push air through BUT ALSO, the air is already going to be moving in the right direction as in it's not hitting the end of a fin like when it enters the rad (which i assume is why more fpi causes airflow reduction). This may be the wrong thought process due to rad roughness and therefore friction causing airflow compromise. ALSO I always see "high fpi rads are for high speed fans" is this true or is it a simplification of the statement "High fpi rads are for high static pressure fans" for example would a stock fan at 1500 rpm perform equally to the renound nf-f12 at 800rpm? Thank you and sorry for long questions. Finally I'd like to mention that I am aware of how many tiny little things make tiny little differences but idc, I want a full, thorough explanation even if it requires hours of reading through other articles because i enjoy learning about all this. ***This question was already asked back in 2k16 and received no answers but with parts on the way, I kinda need answers soon to help me decide on cooling solutions and i thought perhaps reposting will get new people to read this and in turn, answer. Thats the plan at least...***
