Hello.
I recently built a PC that was intended for both productivity and gaming.
I have a 7950X3d, 4090, and 64GB (4 X 16GB) of Corsair Dominator 6600 C32 RAM.
Prior to building the PC, I did not realize that four RAM modules would have severe stability issues on AM5.
Anyway, I found this video to see the optimal RAM speed and timings for my processor:
View: https://www.youtube.com/watch?v=XW2rubC5oCY
Initially I tried setting my RAM to DDR5 6000 (CL 30-38-38-96). I did not change the voltage or secondary timings because I am not that well versed in tuning memory. Please let me know if this is a problem. The default voltage was 1.4V.
Regardless, after using MemTest86, my RAM initially appeared to be stable. I had no problem doing doing any productivity tasks or running games.
This was until I started playing Battlefield 2042. The game would sometimes crash. Sometimes it would just close, and sometimes it would cause a blue screen and my PC would shut off.
I then cleared my CMOS and ran my RAM at the factory speeds (I think it was at 4800 with loose timings). Then I had no problems playing Battlefield 2042.
I still wasn't happy because I paid for 6600 C32 RAM and was hoping to get more out of it.
I then referred to the QVL list of my motherboard (ROG Crosshair X670E Hero) and saw that it supported 4 X 16GB Kingston RAM at 6000 40-40-40-80. Obviously I have Corsair RAM but I decided to give it a shot because the Kingston RAM uses SK Hynix and from my understanding, my Corsair RAM set is also SK Hynix. I don't know if this means much but I gave it a shot.
I tried it out, and yet again Battlefield was crashing. I then tried increasing my voltages from increments of 0.25. I went from 1.4V to 1.425V to 1.45V to 1.475V to 1.5V.
I thought increasing RAM voltage was supposed to make RAM more stable. Anyway, as I kept increasing the voltage, I noticed Battlefield was crashing more and more frequently. Once I went to 1.475V, I was blue screening before even launching the game. Once I went to 1.5V, I was blue screening before I even fully booted up Windows.
I looked back at the QVL list and I saw that the supported 4 X 16GB Kingston RAM at 6000 40-40-40-80 was set at 1.35V.
Since increasing my voltage was making me more unstable, I thought it was worth a try lowering my voltage.
Anyway, I lowered my voltage to 1.35V and I am finally getting a stable 6000 40-40-40-80. Battlefield runs no problem.
Anyway, after getting my RAM speed stable from 4800 to 6000, I noticed that the FPS gains were marginal (if not negligible).
Does RAM speed matter that much at 4K resolution?
I don't want to leave any performance off the table. Do you think it is worth trying tighter timings at 1.35V or is this a recipe for disaster? I would like to tryout 6000 30-38-38-96 at 1.35V. Do you think this is feasible, or should I just cut my losses and stick with what works?
