[SOLVED] Does RX 560 4GB Graphic Card need external power source?
Darkbreeze
No, it does not require supplemental power from a 6 or 8 pin connector. So in that regard you are ok. However, that power supply is incredibly bad. I won't tell you not to use it, but I wouldn't advise it either. Chances are good that power supply cannot even supply half of it's rated capacity and you stand a good chance of having either the power supply or something else fail if you use it with that gaming card.
I'd look for a better power supply first.
Darkbreeze
