Question Does Ryzen 5 2600 CPU has built-in graphics card?
sonah
143
Hi
I will build my son new desktop and I will go with AMD CPU
does Ryzen 5 2600 has a built-in graphics card as we see in Intel CPUs?
because I want to test the pc without [graphics card] and [WiFi PCI-E Adapter] to see if my build is ok first then I will install them later
https://pcpartpicker.com/list/FjTnbX
Only the 2200G and 2400G have integrated graphics, for 2600 you need a dedicated graphics card. You also don't need a cooler for your 2600 as a fairly decent one is included for stock and small overclocks.
Thanks, richiestang_78 , So you mean I Must Install a graphics card in [PCIe x16] to see the output of the computer?
so AMD didn't use integrated graphics in this CPU to Cut the price down
NO, ryzen5 2600 dont come with an integrated graphics. only ryzen3 2200G and ryzen5 2400G comes with integrated graphics and AMD sell them as APUs.
-i dont think you need an aftermarket cooler with ryzen 2600, stock cooler with comes with CPU is more than enough unless you plan on doing some serious overclocking (somewhere around 4.3-4.5ghz)
-you can skip 650w PSU too 550w is more than enough for GPUs upto Rtx2060
-getting 250gb Nvme + 1 TB HDD is a better option than getting 1tb sata SSD
-on a side note
i do have a Ryzen3 2200G build, its a lot better than any intel integrated Graphics. its Dirt cheap Chip and can run all AAA titles, it put a smile one your face smile i dont thing even a 2080Ti in SLI could ever put.
