Does SAPPHIRE Radeon™ RX 460 need 6 pin connector
RandomGamer201
Commendable
Sep 5, 2016
92
I want to buy the new SAPPHIRE Radeon™ RX 460 but my power supply dont have 6 pin connector does SAPPHIRE Radeon™ RX 460 need 6 pin connector?
Hey, don't get the Corsair VS450. I have several of those in my internet cafe. They run good even with 24/7 use. I've had them for 3 years. However, they are really cheap and low quality power supplies. Some of the PCs won't turn on because of them. The fans will start spinning then stop, then the PC will try to turn on by itself, then stop again, it does that over and over again. I usually fix it by re plugging the cables and resitting the RAM. It's okay for me to do that occasionally since the PCs are only being used in the internet cafe. However, for personal use, I would not recommend it. Get a SeaSonic S12II or M12II 520, or an XFX TS 550 if ever you would get a new power supply.
You mean, of all existing RX 460 models from any brand? I don't know :) The webpage of the company should show this info. For example, for Sapphire, you go to the product page (for example for the RX 460 NITRO: http://www.sapphiretech.com/productdetial.asp?pid=72407812-0BE6-49E0-B569-1364FAE7F4D7&lang=eng), click on "Specifications" (roughly in the middle of the page), and at the bottom of the specifications' list you will see "1 x 6-pin AUX Power Connector". If you go the non-NITRO RX 460 (http://www.sapphiretech.com/productdetial.asp?pid=9C9F764B-490D-45EB-B6B6-A40A2AF43984&lang=eng) wou won't see that line about the extra power. Each brand has such a specifications' list, you'll have to check it. Or maybe the store where you are looking into can tell you this, but it's always more reliable to check the page of the make.
Which is better gtx 750 ti or rx 460? I'm planning to buy gtx 750 ti because it is low power consumption and i won't change my generic PSU. when i buy rx 460 I must have to buy a true rated PSU also.
