Does "Speed Fan" always show the correct temperature?
headbanger2894
20
RealTempGT seems to be detecting a maximum core temperature of 40C and my BIOS was showing a temperature of 30C the last time I looked. While SpeedFan is showing an average temperature of 80C.
Should I be worried or do more testing?
mesab66
893
I'm a little wary with this also! It really depends on how accurate the selected sensors are. Some folc actually physically add their own - in certain circumstances (inexpensive to do).
There are other hardware monitors available - most folk use >1.....e.g. hwmonitor
SpeedFan has always been wrong for me on CPU temp with my current system. The diode it's detecting is definitely not the CPU temp. Probably VRM temp, is my guess.
Try HWMonitor to be sure, but I'm 99.9% sure that SpeedFan is just detecting the wrong sensor diode.
kelthic
1,078
Because of the programming and the differences in sensors, motherboards, cpu's, etc., the temps can differ for different programs, different cpu architectures, motherboards, etc. They may not be correct at all. As DJ mentioned, try a different program and see if the temps continue to read the same. If they look good in another program, i would say it's very likely that it's SpeedFan that is wrong.
It seems to be one of the least accurate programs for monitoring temps. It seems like when people come in here with wrong temp readings the program they are using is Speedfan. I like HWMonitor and Core temp so far I've had very little problems with these programs.
