J Joewalk11 Reputable Jan 8, 2016 200 0 4,690 Jan 30, 2016 #1 Does the EVGA 750Ti SC 2Gb DDR5 require any external power from the PSU or can i just plug it into the pci 16x slot and it will work?
Solution Gam3r01 Jan 30, 2016 If you mean this model: http://www.newegg.com/Product/Product.aspx?Item=N82E16814487024 No, it does not have extra power connections. Just slot.
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Jan 30, 2016 Solution #2 If you mean this model: http://www.newegg.com/Product/Product.aspx?Item=N82E16814487024 No, it does not have extra power connections. Just slot. Upvote 0 Downvote Solution
utroz Splendid Nov 9, 2010 2,187 4 21,565 Jan 30, 2016 #3 No did does not. As far I as know.. Upvote 0 Downvote
