Maybe if I remove the front panel will that help?Looking at the case the airflow from the front will be very poor. They chose form over function for the front.
Not yet![]()
from the provided angles i can't see the gap between the front panel and the case.
if it's wide enough to provide adequate airflow you would feel quite a bit of air being sucked in around it.
it also appears to not have any dust filters for the front panel.
if these gaps are large enough for good airflow this may lead to very heavy dust buildup inside the case on GPU, CPU & cooler, RAM, etc.
removing the front panel would make this buildup even quicker.
have you already started building in the case?
those appear identical to me.Not yet...
I think that’s the wrong one. I think it’s this One:
I see a filter, or so I thinkthose appear identical to me.
just a white version of the same case.
think i'd just return it if already purchased.
Ehh probably not a filterthose appear identical to me.
That card has less than a 200 watt TDP that case should be OK for the card.Ehh probably not a filter
Hmmmm, AlrThat card has less than a 200 watt TDP that case should be OK for the card.
I don't see a problem using that card in that case with those fans!Hmmmm, Alr
