Does the Asus Crosshair VI Hero Support a front panel reset button and HDD led?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
My case is the Zalman Z11 Plus, and the motherboard I'm planning to buy it the Asus Crosshair VI Hero, does this motherboard have front panel reset button and HDD light?
Thanks in advance
it shuld, otherwise wouldn't be a standard atx motherboard
if you download the manual from asus site, does it show the front header the connectors? i would be surprised if it wouldn't have those two, with the reset and power button, hard disk led and power led
yes, custom motherboards for small pcs from dell, hp, acer and similar big brands that usually use a specifically developed shape of pc with a specifically designed front panel, they often use a big single connector, making almost impossible to reuse the case or the motherboard without hard to find adapters that might or might not exist
