Does the ASUS Prime B250M-A Motherboard come with a Built-In Wireless Network Adapter?
Jack_202
Commendable
Dec 10, 2016
41
Hello,
So I've been doing some research but can't find an answer - does the motherboard in the title come with a wireless network adapter? So I can connect to the internet without using an ethernet cable or buying a usb network adapter?
Any help would be great, thanks.
According to the official specs, no, it doesn't.
The specs are here:
https://www.asus.com/us/Motherboards/PRIME-B250M-A/specifications/
This is actually not an issue at all - you can always get an USB wireless stick or a PCI-e x1 wireless network card.
The specs are here:
where did you find that? Under what "section"
