Does the back of an ATX Motherboard get hot? Need to know ref sound-dampening?
PeterZ640
339
I want to put some Dynamat sound deadening material on the other side of the rear wall of my case.
Obviously I would not put it between the motherboard and the rear case wall. So airflow afforded by the 6mm motherboard support posts would not be affected, but on the other side.
The case is for an ATX board and some EATX boards, and has a large cut out circa 150mm x 170mm where the CPU is. Naturally this would be left open for airflow.
I ask about the heat, as Dynamat is about 3 or 4mm thick tar like substance with a think silver foil on one side - it is sticky on the tar like side.
Basically if one sticks this on thin tiny metal, it sounds like its 5mm thick solid steel after application.
My idea is to put it on the solid part of the rear wall to deaden sound. And on the non windowed case side, a d on the roof and floor ( obviously not blocking any vents. ) just reinforcing the thin steel parts - so they sound as if they are 5mm thick steel.
Then I wondered if the motherboard got hot on the back of the pcb, and was supposed to transmit the heat through the flimsy thin circa 0.7mm rear case wall?
I Assume not, as there is an air gap created by the motherboard support posts circa 6 mm high.
I have plenty of Noctua fan power i.e. 3x 140mm intake and 3x 140mm exhaust, and 2x 150mm fans on the Noctua air cooler. All controled by PWM 300 to 1,500rpm.
I just thought it would reduce the noise level when the fans needed to go into full revs ( which is not often.) and make an almost silent case - totally silent in low rpm mode,
Any views - would this be OK.?
Hi
Its fabulous stuff for audio. I had the doors of my Mercedes SL lined with it - when you shut the door it sounded like you were slamming a 9" thick steel bank vault.
It also sounded like you had a subwoofer in the door somehow!
I will try and find it and post soon.
OMG
I Was just typing away on my Windows 7 sp1 Laptop, and it said it was shutting down, and then started loading Windows 10!
My laptop has no support from Sony ( now sold the Vaio PC business) for this, and I cerainly did not accept this bloody upgrade.
What the hell do, I Do if it doesnt work!
What a time to do this to me - my super new Workstation is in bits! Due to a faulty Motherboard and its being RMA'ed as we speak.
Sorry to rant - I need this like a hole in the head!
OMG I wonder what will happen to all my specialist Photo Software.?
Oops just noticed its a thermal insulator. So the question is ...
Would isolating the rear case wall increase the motherboard temp.
Nb all the fans are in the motherboard side - there are none on the 2" cable management side.
Or maybe just put a few thin strips on the back wall as that also deadens any vibration.
Thanks its a 140 TDP or watts Intel Xeon CPU.
BTW there is a 6" x 7" cut out behind the CPU area, I guess its so one can get at the back of most CPUs to put on a coller backplate. Naturally I wont conver that :)
I suspected most of the heat would be on the other "facing " side, where all the components are mounted.
Thanks thats a great idea, its a Supermicro X10SRA-O 2011-3 socket for Xeon CPUs.
It will look there.
