I have a gigabyte GA-EP45-UD3R motherboard that will only turn on when the green wire on the power supply is jumper'ed to ground. Well.. I have to clear the cmos first, then jumper the wires and she boots. I have to clear every time I boot, btw. Once shut down, the motherboard will not boot if I don't clear the CMOS. I have updated the BIOS to the latest firmware several times while booted and loaded defaults, but it does not help. And shorting the power pins on the motherboard does nothing.
Because of this I am sure it is a chip problem. But I don't know which chip triggers the motherboard to turn on and stay on (a relay of sorts?). The motherboard has 2 bios chips, so I am not sure if 1 would cause the other to fail too..?
Thanks for your time.
Robert
Robert
