A Advanced_1 Reputable Nov 18, 2015 5 0 4,510 Dec 1, 2015 #1 Does The Corsair 200R come with CPU and GPU fans? A simple yes or no would help. Here is my PC. http://pcpartpicker.com/p/kshwdC
Solution Dark Lord of Tech Dec 1, 2015 Does The Corsair 200R come with CPU and GPU fans......the answer is no , just a couple of case fans. Fans Included are case fans. Front: (x1) 120mm Rear: (x1) 120mm
Forever Oleg Admirable Jul 15, 2015 3,280 0 8,960 Dec 1, 2015 #2 Corsair 200R does not come with a CPU fan. Your CPU will come with a CPU fan. Also, is the build a subject to change or is it what you already bought/have? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Dec 1, 2015 Solution #3 Does The Corsair 200R come with CPU and GPU fans......the answer is no , just a couple of case fans. Fans Included are case fans. Front: (x1) 120mm Rear: (x1) 120mm Upvote 0 Downvote Solution
CorsairJoseph Reputable Nov 7, 2014 300 0 4,960 Dec 3, 2015 #4 If you are asking about CPU cooler, then no, it doesn't come with CPU fan/cooler. Upvote 0 Downvote
