A abodeking1 Proper Nov 9, 2018 104 0 180 Dec 27, 2018 #1 Does the corsair h115i pro fit in nzxt h700i case Top mount
Solution Dark Lord of Tech Dec 27, 2018 Yes, should be plenty of room , Rad support should be 360mm for top and front mounts.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,612 1,777 159,590 Dec 27, 2018 Solution #2 Yes, should be plenty of room , Rad support should be 360mm for top and front mounts. Upvote 0 Downvote Solution
A abodeking1 Proper Nov 9, 2018 104 0 180 Dec 27, 2018 #3 Yes, should be plenty of room , Rad support should be 360mm for top and front mounts. is that right that top mount better than front mount ?? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,612 1,777 159,590 Dec 27, 2018 #4 Yes I would use the top. Upvote 0 Downvote
