Perhaps not though with some creativity you could get it to fit up there. In essence any 2x120mm fan mounts will accept a 240mm radiator setup but in your chassis's case there is a small separation between the two fan mounts up top.
^ Shows that the fans will get in the way of any motherboard connector, rams or power delivery heatsinks on the motherboard so a couple or a lot of factors need to be considered.
