Does the GeForce GTX 1050Ti 4GB GDDR5 work for my pc?
YourBudie
I've been looking for a graphic card upgrade for quite some time now, and would like to know if the 1050Ti would work.
Specs:
8x Intel Core i7-2600 CPU @ 3.40GHz
NVIDIA GeForce GTX 550 Ti
Motherboard Chipset: Intel H67
12GB Ram (DDR3)
Cooling i dont know
Monitor: Generic PnP Monitor
Check to see if your motherboard has a UEFI bios. If it does you should be fine with that card. If it has the older non UEFI bios, I'd contact the company that makes the card, ASUS/MSI/etc. and ask them if the card will work with your older motherboard.
Use a program called Speccy to get detailed information on which motherboard you have. The program is free and it's a small download.
