G
Guest
Guest
I am getting a gtx 1070 Founder's Edition but I don't want to get into water-cooling, would the 1070 be ok without?
Thanks
Thanks
Idle temperatures are excellent, which is no wonder since the fans don't stop in idle. During gaming, the card goes above 82°C, which results in lower clocks due to Boost 3.0.
NVIDIA’s own reference design suffers from severe throttling just after few minutes. It probably wouldn’t be that bad if not the frequency spikes. While average clock is somewhere around officially stated boost clock, those spikes cause micro-stuttering, which negatively affects gaming experience.
"Founders Edition suffers from a horrendous amount of throttling and it runs +- 150 MHz lower all the time."
Meanwhile, MSI GTX 1080 GAMING X generates almost a straight line for GPU frequency (~1910 MHz), with no spikes and rather constant sub-70 C temperature. This should mean that the gaming experience will be much better, and card should theoretically generate better results in most tests. Also according to H.I. this is also the best custom design they so far tested.
