Does the msi geforce gtx 750ti have an external power connector?
yes it will. but you might wanna consider buying a new rig there m8. seeing how it only supports ddr2, and is lga 775 socket. but anyways, you could get an gtx 1050ti, in my opinion which roughly cost the same (depends on your region), performs way better than the rx 460 and gtx 750ti which doesn't need an external power connector either. any brand will do (recommend the galax oc or exoc. and the igame brand). either than that nothing else.
no the gtx 750ti does not need a 6pin pcie. but why not go for the rx 460 instead? the price range is similar to the gtx 750ti yet performs better. also, why doesn't your gpu have a 6pin or 8pin etc? I would say buy a better gpu, as all good power supply supposed to have. otherwise you might circuit the other components and waste your money.
