Question does the MSI H310M PRO-M2 PLUS mobo work with msi rtx 2070 armoured?
Metal Messiah.
980
181
640
23
Have you properly plugged the MONITOR cables to the GPU, and not the onbaord graphics ? Which OS do you have ? Which version of Graphics driver are you installing from NVIDIA's website ? What does it say under the Device Manager settings, under "Display Adapters" ?
"Microsoft basic display adapter", or some other thing ? Make sure you are installing the correct driver version (32/64 bit), depending on your OS build.
Apr 20, 2019
when i try downloading the nvidia drivers it just comes up i need to insert an nvidia gpu. i got a 850 psu so it should get power
The only way that Gforce Experience wouldn't detect a properly connected and powered (nVidia) GPU is if the GPU or the motherboard is defective
What, EXACT, PSU do you have?
Have you connected BOTH the 8 and 6-pin PCI/E power cables to the GPU?
