Sorry if this is a stupid question, but I've been trying to work on it myself for a few days now with no luck. I've seen a lot of threads about front panel audio not working but the only fix I saw that applied to me (Unticking something in the realtek audio center to disable then re-enable front panel audio) didn't work.
I have a MSI Z270-A PRO MOBO, and in the manual here https://us.msi.com/Motherboard/support/Z270-A-PRO.html#down-manual
I don't see where, if anywhere, the front panel audio and mic is getting connected to on my case.
My case is a Phanteks Eclipse P400, which has front panel mic and audio ports and two 3.0 usb ports. The usb ports work.
I can connect my headphone and mic through a 3.5 headphone and mic to USB connection in the front, but read somewhere it's better to use the 3.5 connections.
My back audio and everything else works fine. Also I'm pretty sure I'm using the right sound source.
I don't have a sound card and I'm running windows 10 if that matters, thanks in advance.
