Hi,
I currently have a number of cooling related issues with my PC, but in my opinion have OK equipment for what I am doing - I do not over clock the PC etc.
The main question I have is, does the orientation of a heat sink change it's effectiveness for calling the CPU?
E.g. If you have a cooler like the "Enzotech Ultra-X", does the bend of the heat pipes make a difference to how cool the CPU will become if they are either going up or down.
I have a midi tower case and therefore when mounting a number of heat sinks, am limited to either the heat pipes going up, across then down, or down, across then up to the fins - Is there a preferred direction for these?
If I take this a step further to add clarification, if my mobo was laying flat on the floor, when the heat sink is connected, the contents of the heat pipes will drop (by gravity) to above the CPU, then if heated up, will evaporate and make they way up to the fins/fan - by using a midi tower, does this process still work, or should I look at getting a specific type of CPU cooler?
Hopefully you may be able to provide some insight to this, any feedback would be welcomed.
(obviously this may not be the most important criteria for everyone).
