coolbest88 :
I'm going to make my first gaming pc and I am going to use this case but i'm not sure if this case has enough airflow for gaming
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811353025
Pro Tip: Case Fans don't actually cool anything other then the mobo chip set, but in terms of gpu/cpu cooling. All they do is replace the hot air after its blown to cool the cpu or gpu with coolish air (moving) to dissapate the heat inside the case + feed the HSF on the cpu and the gpu cooler. But yes, it has 2 120mm intake fans to blow coolish air in and a 120mm exhaust fan to blow heated air out.
PS: I reccomend you go to www.pcpartpicker.com for selecting these things
