does the xbox 360 E supply power work on regular xbox 360?
Your asking if a elite power supply brick would fit another xbox 360.
There are about four types of the power bricks that exist.
Each have different power rating outputs.
So Microsoft in there wisdom keyed each one.
So one power brick from a later revision of an xbox could not be used or plugged into another of a newer or older revision.
so its not possible that an xbox 360 e brick power an xbox 360 s in any way
If you attempt it first check what the wattage output of each power brick provides in DC voltage, and also how many amps.
If they are different then I would not chance it.
But as I said that is one of the main reasons why each of the power bricks are keyed on the end you plug into the xbox 360.
If you look at both the ends from each of the power bricks that fit into the xbox 360 you will see a plastic key.
If they are in the same place, and the voltage output and amp output are the same on the sticker on them then yes.
If not no dice.
No, it will not. The XBOX 360 E power supply is 135W. The regular XBOX 360 is 150E, 175W, or 203W depending on which model you have. There is no way to make the XBOX 360 E power supply work in a regular XBOX 360.
I have seen adapters to make the regular XBOX 360 power supply work on the XBOX 360 E, but not the other way around.
