Does Thermaltake SMART SE 730W Modular a Haswell Compatible PSU ?
Jaydee Ramos
224
I found this PSU thats cheap but great PSU and its semi modular that fits on my tight Bitfenix Prodigy M chassis, my only problem is I don't know if its haswell compatible..
My F. Rig
CPU: INTEL CORE i5 4670K - P10950
CPU COOLER: CORSAIR H55 QUIET LIQUID COOLER - P2870
MOBO: GIGABYTE GA-Z87MX-D3H - P6050
GPU: SAPPHIRE R9 280X VAPOR-X TRI-X OC 3GB - P16950
CHASSIS: BITFENIX PRIDOGY M - P3350
RAM: CRUCIAL BALLISTIX SPORT 8GB DUAL DDR3 1600 CL9 - P3900
PSU: ---
HDD: WESTERN DIGITAL CAVIAR BLUE - P2700
My friend has that psu, it has a Haswell ready sticker on the box. So if you are willing to trust them ;]
But it doesn't really matter though. That's not some totally, completely new form of chips so that they need special power supplies.
Once again - it really isn't the best choice. BUT, if you are on the budget or you you don't have too many choices beside it, I'd say go for it.
Just to be clear, I'm talking about this psu http://www.ebuyer.com/631115-thermaltake-smart-se-730w-semi-modular-80-bronze-power-supply-sps-730mpcbeu
When you do the shopping, I recommend to find the pro. review on the item you are interested. If you can't find one just don't buy it, because just like buy your clothes, if you don't try it on you don't it will fit you or not. Review just like someone try it for you.
