does these parts work together ?
skulls_crusher
12
please tell me if these parts work together
1-Corsair Professional Series 860 Watt Digital ATX/EPS Modular 80 PLUS Platinum Power Supply AX860i
2-Asus Z87-Deluxe DDR3 1600 LGA 1150 Motherboard
3-Western Digital Bare Drives 3TB WD Black SATA III 7200 RPM 64 MB Cache Bulk/OEM Desktop Hard Drive WD3001FAEX
4-EVGA GeForce GTX780 SuperClocked 3GB GDDR5 384bit, Dual-Link DVI-I, DVI-D, HDMI,DP, SLI Ready Graphics Card (03G-P4-2783-KR) Graphics Cards 03G-P4-2783-KR
5-Intel i7-4820K LGA 2011 64 Technology Extended Memory CPU Processors BX80633I74820K
6-Corsair Vengeance 16GB (2x8GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CMZ8GX3M1A1600C10)
7-Samsung Electronics 840 Pro Series 2.5-Inch 256 GB SATA 6GB/s Solid State Drive MZ-7PD256BW
Thank you!
and please if i can make any of these better tell me
Depending on your usage, you might not notice the difference, but for highest performance, changing the motherboard to lga 2011 is better, and if you can afford it, you might think about changing the cpu to a 4930k as well.
ok if i want to change the processor what should i get?
& i'm getting one 780
what if i want to change the motherboard
& which one is better to change?
but i want the best that i can get so is it better to change the motherboard or the processor again i want the best
Keep the motherboard and get intel xeon e5-2690, the CPU only is worth around 2000$
thank you so much man 😀
that cpu is lga 2011, so it wouldn't work with the originally selected motherboard (which was lga 1150).
ok i'm sorry i know i asked to much but what's the best lga 2011 motherboard ?
The ASRock X79 Extreme11 and Rampage IV are EATX boards, so we'll need to know what case the OP is planning on using, so we can make sure they fit. The Sabertooth X79 is probably a good choice for ATX form factor, or maybe the Gigabyte GA-X79-UP4. There's too much variation between different users' needs to definitively say one motherboard is "the best".
i haven't chosen a case yet i'll chose one after i get the parts
