AlfexOmega Honorable Oct 7, 2013 18 0 10,510 Nov 18, 2013 #1 On some websites it says 2 and some it says 4, I need a power supply with 2 6+2 connectors Powersuplly - 750W Corsair Builder Series CX750M
Solution Dark Lord of Tech Nov 18, 2013 4 PCI-Express Connector 4 x 6+2-Pin It has 4 so you are good to go.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Nov 18, 2013 Solution #2 4 PCI-Express Connector 4 x 6+2-Pin It has 4 so you are good to go. Upvote 0 Downvote Solution
AlfexOmega Honorable Oct 7, 2013 18 0 10,510 Nov 18, 2013 #3 4 PCI-Express Connector 4 x 6+2-Pin It has 4 so you are good to go. Thanks, i was really worried xD Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Nov 18, 2013 #4 It has 4 so don't worry , your all set. Upvote 0 Downvote
