Does UDIMM fit with DIMM
erick_9
Commendable
Feb 28, 2017
33
So I used the crucial Parts scanner it it told me i need DDR3-1600 UDIMM ram. I found some but it says they are DIMM not UDIMM. Will they fit into my motherboard. Are they the same?
What motherboard and CPU?
Technically UDIMM is a type of DIMM but the two terms are often used interchangeably to both mean an unregistered memory module which is what pretty much all consumer devices use. This is in contract to RDIMM, used primarily by servers.
Its an old workstation im trying to upgrade. The mobo is a LENOVO 5474W8M and it has a i5 760 CPU
