does undervolting increase FPS (frames per seconds) ?
No, it does not. The reason for undervolting stems from the need to reduce heat output/stress on the processor. The lower voltage you can run a CPU at, the less heat it will output. It in no way impacts performance, and will actually lead to stability problems should you undervolt your chip too much.
